Especificaciones de los diferentes modelos de sr20det
nformacion sacada de Shaw Communications
Specifications for RED Top SR20DET
180SX 91-93 and Silvia 91-93 **
Displacement: 1998cc (2.0 liter)
Cam type: DOHC 16 valve, chain driven cam sprockets
Bore and stroke: 86mm x 86mm
Compression: 8.5 : 1
Horsepower: 205ps at 6000rpm
Torque: 203 ft/lbs at 4000rpm
Stock boost: 7 psi
Throttle body bore: 60mm
Injector size: 370cc/min
Turbo specs:
Compressor: T-25, 60 trim 56mm BCI-1 compressor.
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
Center Section: Journal bearings
Performance:
The stock turbo will be safe to 13-15 psi. After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage. The engine should produce 230-250 RWHP at safe boost.
Specifications for Black Top SR20DET
180SX 94-98**
Horsepower: 205hp at 6000rpm
Stock boost: 7 psi
Turbo specs:
Performance:
Specifications for Black Top S14 T28 VTC
Silvia 95-98**
Horsepower: 220hp at 6000rpm
Torque: 203 ft/lbs at 4800rpm
Turbo specs:
Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing
Center Section: Ball Bearing
S14 SR20DET’s use a different ECU and harness, these are extremely expensive and hard to find.
Variable valve timing system and a different turbo are the significant changes from the S13 SR20DET engines.
S13 uses ‘low port’ intake design vs. S14 ‘high port’ design.
Performance:
The stock turbo will be safe to 13-15 psi. After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage. The stock engine should produce 250-260 RWHP at safe boost using stock turbo. Upgrading turbo, fuel and rest of need parts will yield 300-375.
**Specifications S15 Black Top SR20DET
S15 Silvia 99-**
Horsepower: 250ps at 6000rpm
Transmission: 6 Speed, Close Ratio
Injector size: 480cc/min
Turbo specs:
Turbine: Inconel turbine wheel. Cast divider wall between turbine discharge and wastegate.
This engine is expensive and hard to get. If you are on a tight budget, please consider other options as the money you save from buying this engine can be better used to build up a really nice Red Top.
Additions: 6 speed manual transmission. The 6 speed cannot be used on the S13 and S14 motors, and uses a different driveshaft. Speed sensor is located in the differential. The 6 speed is cool, but is not as strong as the 5 speed from the older cars. There is basically 6 gears inside the same housing that was designed to hold 5 gears. This makes the gears smaller and weaker, therby breaking more often.
muy interesante abe :wink:
Como es una duda q siempre preguntan muchos foreros lo voy a poner dentro de los tutoriales de ayuda en mecánica…Gracias Abe… :wink:
de nada!
‘Abe’ CESAR!!! :wink:
gran info!!!asias!
No viene mal recordarlo !! El que mas me gusta es el del S14 pero con la tapa pintada roja mmmm jaja
